How a 3D pancake printer should set each parameter
Posted · How a 3D pancake printer should set each parameter
I have a pancake printer, I want to edit and print through CURA, but there is no choice of this printer model added in the software, what should I do, and how do I set the parameters inside, the following link is related information about the pancake printer, who can help me, which model of printer I should choose can match my printer, and then how to set the parameters inside to control the function of my printer, thank you very much, I love you!!!
https://pancakebot.com
https://github.com/PancakeBot
https://www.scopesdf.org/scopesdf_lesson/bytes-to-bites-drawing-pancakes-with-g-code/
    Hey @amy1234,
    Welcome to the Ultimaker Community 🎉
    I don't have any experience with 3D printing pancakes.
    Since Cura is open source, you or anyone else is more than welcome to work on adding this 3d printer and create a pull request yourself. You can find instructions on how to add a new 3D printer definition here: https://github.com/Ultimaker/Cura/wiki/Adding-new-machine-profiles-to-Cura
    If you are stuck in any way, please reach out! I'll be happy to help out.
    But checking out https://github.com/PancakeBot/PancakePainter it seems more tricky than just adding a printer.
    We do have this user who 3D printed chocolate, perhaps you can get some tips?
    @amy1234 did you try that Pancake Painter software?  It's simple and looks pretty good.  You can bring images in to trace.  I don't know how much more you would need for pancakes.
    I never did get the chocolate printer to work right.  Maybe if I would have put the printer in the refrigerator?
    煎饼打印机附带的软件不好用,我想换一种方式打印,如何在CURA上添加新打印机,我阅读了您给我的链接,但非常抱歉我对这方面不是很专业和了解,我认为有用的信息在我提供的链接中, 煎饼打印机软件也是开源的,希望你帮我设置一下,谢谢
    4小时前,MariMakes说:
    我在尝试煎饼画家🤩时玩得很开心
    它看起来很简单 🤷 ♀️
    Hey @amy1234
    If I understand google translate correctly, the software isn't working for you.
    We are not the correct place for troubleshooting the software.
    If they are open source I suggest to leave a report on their github: https://github.com/PancakeBot/PancakePainter/issues
    I hope you get some help, because the last time the code has been updated is in augustus 2018.
