Unless you changed the hardware to non-standard parts, you do not need to calibrate the e-steps. The e-steps are a function of how many steps per rotation the stepper motors are, and the gearing of the feeder. If the printer is consistently underextruding, something else is going wrong. For example the feeder could be slipping, or skipping steps. You should not fix that with the e-steps configuration.
Do you know that the Ultimaker 3, like all other Ultimaker printers, is made to use 2.85 mm filament (as opposed to 1.75 mm filament)?
ahoeben 1,992
