Dustin, thanks for the input so far. I did a print on 60mm/s and still had the same bulges at the corners when using Cura. Then I did a 100mm/s print using Prusa Slicer and the cube printed perfectly at the corners. I'd rather user Cura, so I'd really like to figure this out in the settings.
Dustin 160
Print speeds of 50-100mm/s is going to be a big factor of your issue.
Try print speeds of 20-40mm/s and see if the results are better.
If they are better at the lower speeds, the issue will be completely hardware and firmware related.
(belt tension, acceleration speed, jerk, etc)
If your results are better at the slower speeds, try retuning your Linear Advance at those lower speeds. Results should make more sense.
Realistic speeds for your printer are 30-60mm/s range and on the low side if corner quality is your focus. That 3D Printer is not a highspeed printer out of the box.
