Mac Cura 5.2.2 won't launch
Go to solution Solved by MariMakes,
Posted · Mac Cura 5.2.2 won't launch
Running MacOS Catalina 10.15.7. Downloaded 5.2.2, copied it to the Applications folder. Right clicked on it and selected open, confirmed that I wanted to run it. Confirmed again after the OS checked it. Then it disappears out of the force quit window. If I try and start art again it immediately disappears. If I delete the application and copy it over again from the dmg it goes through the process again.
Any ideas on this?
Thanks
    • Solution
    Hey @electblu,
    Welcome to the Ultimaker Community 🎉
    Cura 5.2 supports Mac OSX 11 Big Sur or higher.
    This is because the tools that we use to create Cura builds no longer support these versions of Mac OSx.
    You can learn more about which version is compatible with your OS here
    https://support.makerbot.com/s/article/1667337917781
    Sorry for the inconvenience
