Posted · Is there a way to hide (not delete) the default print profiles?
I want to use my own profiles, which are based on the defaults with few modifications (wall count, random infill start, type of infill, etc...).
It gets a bit messy if the default profiles are always in view - but I don't want to delete them either, in case I want to get back to the originals if I decide my changes aren't good.
Happily using Cura 5.1.1 at the moment, in case there's an easy way in newer versions.
    Posted (edited) · Is there a way to hide (not delete) the default print profiles?
    To answer your question: No, there is not.
    Deleting them from your Cura install would be a very bad idea, because it would break your custom profiles based on the standard ones. A custom profile is always a standard profile + your changes to it, so if you were to remove the standard profile then things "explode" 😉
    Edited by ahoeben
    • Laugh 1
