Posted · How to start Post processing plugin after all others plugins?
Hi all,
I have problem, that Linear Advance Plugin starts after Post Processing Plugin. I need to start Post Processing after Linear Advance Plugin. How to do set plugin`s ordering?
Regards Ondrej
    Posted (edited) · How to start Post processing plugin after all others plugins?
    Hello
    I don't think there is a possibility to solve this problem via a parameter.  Maybe @ahoeben could give a more accurate answer.
    The execution of the plugins follow I think the order of loading and the order of loading is according to the alphabetical order
    First there are the plugins loaded in :
    <Software>Ultimaker\Ultimaker Cura XXX\share\cura\plugins     so  PostProcessingPlugin   in the first place
    Then the plugins in :  <User>AppData\Roaming\cura\XXX\plugins   like  LinearAdvanceSettingPlugin or ArcWelderPlugin etc .
    So if you want to modify this order you can move  the Folder  PostProcessingPlugin   into the User plugins directory or move the LinearAdvanceSettingPlugin into the Software plugins directory .   As on a alphabetic order LinearAdvanceSettingPlugin  will be loaded before PostProcessingPlugin   you will get the right order but it's just a workaround  and you will have to do it for every new Cura Installation.
    Edited by Cuq
    Note : If you want to use the postprocessing Script after the linear Advance it's certainly because you want to modify the code generate by the Linear Advance . In this case the best solution would be to modifiy the linearAdvance plugin or send a [Feature Request] to @ahoeben
    Edited by Cuq
    Not without modifying code.
