Linux AppImage Printer Install on start-up
D1sc1pleDan
Posted · Linux AppImage Printer Install on start-up
Hi Folks
I'm a dedicated Cura user on Linux, but the AppImage for 5.2.X  requires you to install a new printer each time it starts up.  This was not the case with 4.13.1.  It is a huge faff to have to go through those start-up screens every single time!  Is there a reason for this?
It would be lovely if it would just start up.
Yours in anticipation
Dan
    Hey @D1sc1pleDan,
    Welcome to the Ultimaker Community 🎉
    That's odd, I've never heard of that before. 🤔
    Could there be something wrong with your configuration folder, that's the place where Cura remembers your printers.
    You can find it by :
    1. Go to Help at the top bar of Cura
    2. Select Show Configuration Folder
    I'll bring it up to the team to see what they can do to help. Fingers crossed 🤞
    In the meantime, have you considered using a back-up?
    You can find it under Extensions | Cura Backups | Manage Back-ups.
    That restores your configuration folder so both your printers and your profiles.
    Hey @D1sc1pleDan,
    I discussed your issue.
    There is also a chance that something might have gone corrupted in your configuration file.
    Perhaps this plug-in can help with removing corrupted files.
    https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/StartOptimiser
    Or... If you don't mind starting over you can perform the clean install steps here:
    https://support.makerbot.com/s/article/1667337561461
