does Cura overrides Um2 Settings
MPestana
Go to solution Solved by ahoeben,
Posted · does Cura overrides Um2 Settings
Dear All
I would like to know if the settings on cura , are passed to ultimaker 2+ when printing, namely temperature, fan cooling speed etc... In know some are, like layer thickness, fill pattern, type of adhesion (brim raft, etc....) . Once the file is in printing mode if we go to tune and adjust the speed,  or temperature, of fan cooling, does that overrides the slicer indications?
Thks
    • Solution
    Yes. The "tune" settings start at what is currently printing. You change the "live" value.
    I think that once the gcode file specifies a new temperature or cooling fan value, that may override what you tuned. The speed change in the tune menu works a bit different than the other two values you mention and it is mostly a "multiplier" for the speeds in the gcode.
    Thank you for the explanation
    Regards
        • 27 replies
