Posted
· Modifier Wall Count - Am I doing this wrong?
It's so simple and so complicated. The block has properties and the model has properties. An "Infill Mesh" will interact with a model and change certain things, and as a "Cutting Mesh" the same block will interact with the real model in a different way.
Here is a little Cutting Mesh in the bigger model. The cutter is set to single wall, If you look closely you will see that the small block does indeed have a single wall but the portion of the real model that it has cut still has it's 3 walls - they go around the little block. A problem is that the little block will leave scars on the exterior of the model as it is "cutting" the model and so what it is really doing is leaving a pocket in the model. So that pocket has 4 walls - 3 of the regular model and one wall from the cutting mesh.
It's the scar on the exterior that I don't like.
I'm a firm believer that the slicer should be excellent at slicing the model I give it. If I want the model to be different, I give it a different model. Cura is an excellent slicer, but it will never replace a CAD program. My advice therefore is to alter your model so that area only has a single wall, or you will need to live with some of vagaries of trying to modify a model in a slicing app. It can be done...but it's complicated.
GregValiant 1,364
