Cura crashesor stops
Go to solution Solved by Dustin,
Posted · Cura crashesor stops
Hopefully someone can help me.  I am new to Cura. version 3.2.1  I dont seem to be able to download a later version.  I have been able to print several basic models but not the more complicated ones.  I had a plate adhesion problem but resolved that.
I have a STL file at 70,583 KB.  Cura produces a gcode at 884 KB.  Does this sound reasonable?  Also, Cura crashes at or after? save.  The print produces several layers of the model and then stops.  Is it perhaps that my computer does not have enough free space?  Please help
    • Solution
    Your issue is likely Cura 3.2.1 that was released 5years ago  ... Current release build of Cura is 5.2.2..
    Cura has undergone significant updates since then, even a major one in the last year alone.
