Vase Mode (spiralize) would have been perfect here, yeah.
@MariMakes do you have any idea of what's going wrong here ? I'm not very familiar with Vase Mode, used it a few but on older CURA and it worked fine.
1
Dadkitess 21
Just tried it on CURA 5.1.1 and indeed, while it's doing OK with very basic settings and spiralize, it does not work with the spiralize option. At first, with 0.4mm width, it won't show layer past the 5-6 firsts, and if I reduce it to 0.35mm to test, it's going all the way up but with strings inside the cylinder, not proper spiralzing.
Weird.
Gl0ox 0
Thanks for your feedback Dadkitess,
I was finally able to slice it by changing Special Modes>Surface Mode to "Surface" (instead of "Normal").
Print is on-going (but it's not vase mode, I mean it is not printing continuously (even on the preview below you can see the vertical seam line). I don't know if I could print in continuous rotation by enabling any setting ?
