Changing setting relations after a setting definition has been created
JJFX
Posted · Changing setting relations after a setting definition has been created
The plugin I'm developing adds a number of new settings to a new settings category. Some of them mirror other Cura settings by default and I'd like to change their relations once a user has modified a value.
For example, if the user defines a parent setting I'd like its children to now automatically follow the modified parent instead of their initial value function. Setting the value property seems to only accept defined values and I'm hitting a wall trying to get around this without needing to remaking setting definitions every time.
To clarify, here's a basic example of what I'd like to do...
## Following onExtruderSettingChanged function:
extruder_stack = self._application.getExtruderManager().getActiveExtruderStack()
is_user_value = extruder_stack.hasUserValue(setting)
if setting == "klipper_retraction_speed" and is_user_value:
  for child in ["klipper_retract_speed", "klipper_retract_prime_speed"]:
    extruder_stack.setProperty(child, 'value', "klipper_retraction_speed")
I'm currently using a crude workaround that detects the change, compares previous values then manually sets the children to the parent value but this isn't ideal and a bit buggy.
I suspect there's an obvious solution I'm overlooking but this one is getting the best of me :)
I'd greatly appreciate any insight, thanks!
JJ
    You don't have to implement anything in Python; Cura already handles inheritance for you. Define the "value" of "klipper_retract_speed" as "klipper_retraction_speed". The "value" is a string that gets evaluated by Python, and all registered settings are available as variables in that string. You can also set the value to "klipper_rectraction_speed * 1.05" to have the value 5% higher than that of the "main" setting.
    Thank you Aldo, I don't think my question was very clear. If I understand correctly, I believe you're referring to the initial setting definition. My issue is that I've already defined the inheritance for such settings. In this example, the initial values are defined by Cura's retraction settings but I'm trying to change the inheritance in Python after the user modifies a value as described above.
    "klipper_retraction_speed": {
      "label": "Retraction Speed",
      "description": "The speed in mm/s which...",
            "type": "float",
            "unit": "mm/s",
            "default_value": 0,
            "value": "retraction_speed",
            "minimum_value": "0",
            "minimum_value_warning": "5 if klipper_retract_speed >= 1 or klipper_retract_prime_speed >= 1 else 0",
            "maximum_value_warning": "99",
            "enabled": "resolveOrValue('machine_firmware_retract')",
            "settable_per_mesh": false,
            "settable_per_extruder": true,
            "children": {
                "klipper_retract_speed": {
                    "label": "Retract Speed",
                    "description": "The speed at which...",
                    "type": "float",
                    "unit": "mm/s",
                    "default_value": 0,
                    "value": "retraction_retract_speed",
                    "minimum_value_warning": "5 if klipper_retract_speed >= 1 else 0",
    So my question is, is there way to easily adjust the value in Python so it's recognized as an expression or is this simply too unorthodox? If there is, there are a few other situations where I'd like to implement this as well.
    For reference, here is the repo for the plugin I'm working on.
    I truly appreciate the help!
    Posted (edited) · Changing setting relations after a setting definition has been created
    I'm sorry, I still don't understand. Please provide a scenario, something like this:
    User enters value 'X' for setting 'Y'. 'Z' should happen. By just having the standard inheritance, 'A' happens instead. I could implement it by doing B, but then 'C' happens and that is undesirable because of 'D'
    It is better not to fight the Cura inheritance system, but work along with it.
    Edited by ahoeben
    No problem, it is a bit convoluted. Basically I was trying to accomplish something like the 'value' of "klipper_retract_speed" below. Since this doesn't seem possible, I was looking for a way to do it after the fact in Python.
        "description": "...",
        "type": "float",
        "unit": "mm/s",
        "default_value": 0,
        "children": {
            "type": "float",
            "unit": "mm/s",
            "default_value": 0,
            "value": "klipper_retraction_speed" if hasUserValue('klipper_retraction_speed') else "retraction_retract_speed",
    Hopefully that makes sense.
    Admittedly, I'm realizing I should just take a break and reevaluate. It would make more sense to remove parent settings and simply avoid situations like this entirely. I'm curious if there is a way to do it but I think I'm making things unnecessarily complicated.
    Apologies for wasting your time.
        • 28 replies
