Hi Tom, thank you for your help!
We will probably downgrade to 7.1.3 and skip firmware 8.1.
Unless. is there perhaps another workaround?
Is there a config file or something similar I could modify in DEV mode/SSH console in order to enable an id/key pair?
tomnagel 128
Hi Walter,
We're looking into this, this was unintentional. I am very sorry to hear that this breaks your workflow.
In the meantime you may want to downgrade back to 7.1.3. Please note that this can only be done via the recovery procedure with an SD card, not via the UI panel on the printer.
See this post for a link to the instructions.
Can't promise anything now, but we intend to fix this with a patch release.
