51 minutes ago, Dustin said:Im going to say most likely not possible..
But its hard to understand your question without pictures/screenshots showing what you are trying to do.
So in the image below, the base is 2mm. My printer would print the base and HY the same color. Next I would print the E in red, but wondering if any current post processing in Cura could tell the printer to print the E in between the HY. The z axis would lift up and over the H to print down between.
Dustin 30
