Posted · Clear guide on how to use Brim on Supports only.
Hi, i have some pieces where i want to use brimm on the supports, but the "enable brimm on supports" seems to be not functioning at all.
These are my setting, the brim only works if i enable build plate adhesion and the supports has brim as build plate adhesion setting  indicates, but if ai disable build plate adeshion even with "enable support brim" checked, supports doesnt have brim. i want to use brim only on supports since these pieces have a big footprint and brim is not needd on those.
witouth bed adhesion enabled, but support brim enabled.
thanks for any help
