Setting up Ultimaker S7 - Cura doesn't support S7?
Go to solution Solved by Dustin,
Posted · Setting up Ultimaker S7 - Cura doesn't support S7?
Howdy,
      So I convinced my boss to get the company an S7, huzzah!
I'm glad he's not here at the moment because although the printer is popping up on my profile, it isn't able to being found on the Cloud on CURA.
So I thought, I am going to slice it and then save it on a USB, but wouldn't you know it.  Version 5.1.0 (I believe the latest, without going BETA) does not support the S7?
I tried to add the printer manually via IP address and it says that the printer is either not recognized or not the Host printer.
At this point, I believe... I have a very expensive and very cool looking paperweight.  Please advise!
    I'll download it now, I was selecting Check for Updates and it only said Beta was available.  I will advise if it works!
    Huzzah, started up version 5.2.2 and Ultimaker S7 popped up immediately!
    Thank you so much!  I was sittin here waiting for an email from the supplier and you swooped in and saved me!
