Elegoo Post Processing troubleshoot
JighIV
Go to solution Solved by MariMakes,
Posted · Elegoo Post Processing troubleshoot
Post processing scripts are not activating during the print. I am using a Elegoo Neptune 3 pro with Cura 5.3. I was hoping the latest Cura update would solve the problem but am having the same problem as I did in the last version.  Does anyone have and troubleshooting tips?
Appreciate your time
-JIV
    Hey @JighIV,
    Welcome to the Ultimaker Community 🎉
    Which post-processing script are you referring to?
    What do you want to do?
    A very common one is the Pause At Height script.
    There you have to indicate which flavor you are using.
    Did you select the correct code flavor, I believe you need Marlin.
    Posted (edited) · Elegoo Post Processing troubleshoot
    Hello @MariMakes
    Thank you for responding
    I have been trying to "add a thumbnail" and "Display file name and Layer on LCD"
    Not necessary things but it would be cool to have on the display
    I have not tried the pause at layer feature yet though it should not be long until I do.
    Edited by JighIV
    • Solution
    Hey @JighIV,
    I noticed that displaying information on your LCD needs to be supported with your printer's firmware.
    You can test this by manually adding an M117 into your gcode.
    You can find more information about it here: https://marlinfw.org/docs/gcode/M117.html
    Good luck!
        • 27 replies
