variable velocity or acceleration?
salmos
Posted · variable velocity or acceleration?
is there any way to control acceleration or velocity by X/Y position? I have a delta printer, FLSUN V400, which is pretty fast. So fast that when the extruder is at the edge of the X/Y plane and is supposed to return towards the center, the motor is not fast enough to raise the extended arm with an acceleration of 8000mm/s^2 and a speed of 400mm/s.
My idea: for extruder positions beyond 100mm from the center, an acceleration of 2000 is used. The printing area is 300mm.
THANKS
    There is acceleration and jerk options under the expert settings view.. but I don't think anything such as you described exists.
    Except maybe acceleration for "Travel" moves.
        • 28 replies
