A few bugs with cura 5.3.0.
Mince_Pie
Posted (edited) · A few bugs with cura 5.3.0.
Hello everyone!
First of all, ArcWelder doesn't work in cura 5.3.0. I tried on 3 different PC's, and in all cases sliced models were looks like on picture 1.
The next problem is Initial XY positions for printing with dual-extrusion mode. Iam using klipper, and its has a "save_gcode_state" and "restore_gcode_state" functions, in this case i dont need initial XY position, it would be cool to be able to disable this option(Picture 2).
Picture 1Picture 2
Broken_arc_welder.3mf
Edited by Mince_Pie
    • 2 weeks later...
    Posted · A few bugs with cura 5.3.0.
    The ArcWelder plugin actually works, but Cura just cannot display the G2/G3 curves that the plugin creates. Cura itself does not create G2/G3 commands, so the display of those commands was never implemented.
        • 26 replies
