You may want to consider using alternative build surfaces that are more durable than glass, such as PEI sheets or BuildTak. These surfaces are known for their toughness and can withstand repeated use without being damaged. Additionally, you could consider educating your students on proper print removal techniques, such as allowing the build plate to cool down before attempting to remove the print or using a spatula to gently lift the print off the plate.
Dustin 55
Sadly not at this time.
Can find more details here: https://support.makerbot.com/s/article/000002868
