- Solution
GregValiant 1,044
The build volume is defined in the machine settings. You might be able to cheat a little bit, but you need to be careful. The model needs to fit within your actual build volume.
Go to "Manage Printers" and then "Machine Settings". The X (width), Y(depth) and Z(height) determine the build volume. You can make those whatever you want, but the printer is only so big.
Here is the same model I used above but I've set my Ender to 3000 x 3000 x 5000. I've moved the model from the midpoint to a location 115 from the left and 115 from the bottom. I could slice and print this since it is where my actual midpoint is on the printer. If I move it just about anywhere else, the print head will slam into the end stops.
2
GregValiant 1,044
All you can really do is collapse some dialogs. (This is with Ahoebens "Sidebar GUI" so it may look a bit different than your installation.)
Under the "View" menu you can toggle "Full Screen" but all it does is hide the Titlebar.
chsmith 0
I am trying to make something bigger then the box there is on the screen can that be done
Edited by chsmithLink to post
