Linux Cura problem
E101
Go to solution Solved by rdatoc,
Posted · Linux Cura problem
Hi, im realitivly new to 3d printing and I have a chromebook so I get the linux version on Cura, But when I load up Cura (with micro sd card already reconized) It doesn't give me an option to save to removable drive. (this is after I have sliced it) Open to any solutions 🙂 sorry that the picture is upside down Screenshot2023-04-0211_48_12.thumb.png.ba7fec85d4825c4f648b4d313289a1e2.png
    • Solution
    Posted (edited) · Linux Cura problem
    I stumbled upon this fix for the Cura AppImage, which I installed the latest version of (5.3.0) on my Chromebook.  Previous versions may or may not have the same issue, but this is probably applicable to those versions as well.
    So I looked at the log messages generated by Cura in Terminal for a clue and came across this:
    No applications found for mimetype: inode/directory
    .No applications found for mimetype: inode/directory
    Which started the wheels turning.  Running this to display the default application for the above mimetype:
    xdg-mime query default inode/directory
    came up empty.  So ChromeOS Linux doesn't have a default file manager (like Nautilus or Thunar) and an AppImage can't open files or folders.  This article suggested Nautilus, or rather the Cinnamon fork, Nemo, for ChromeOS.  After installing it (Warning: installs a LOT of packages):
    sudo apt install nemo
    And restarting Cura, voila
    Edited by rdatoc
    Hi. Thank you for replying, I do have nemo installed already, the problem is that it doesn't give me an option to save to a removable drive. Maybe i'm just dumb and don't know how to use the Linux file management system
    Edited by E101
    No biggie.  You can find mounted USB drives under /mnt/chromeos/removable/USB Drive.  Click on the Drive icon to start digging down into the filesystem:
    when I go into ChromeOs it doesn't give me the option of removable (even though the chromebook reconized the usb drive )
    you might need to do a right-click "Share with Linux" on the USB drive with the ChromeOS Files app
    That worked, thank you, one last question, how am I supposed to save, I click the save button it does nothing because I go to my chrome files (preinstalled) and its not there.
    Edited by E101
    you need to manually enter the filename to save.  the filename field is left blank by Cura:
    Thank you it worked.
    Edited by E101
    Just a note: Moved this topic to the correct section on the forum.
    sorry im new and didn't know what to put
    No worries 😃
        • 56 replies
        • 34 replies
