Hi apologies I should have said that this problem only occured after upgrade to 5.3.0. They open fine as projects with previous versions of Cura.
Hi Thanks for your help, sadly this doesn't solve the problem in my case.
GregValiant 1,044
Not all 3mf files are project files. A 3mf file is an archive (similar to a Zip folder) and contains sub-folders. In a project file one of those sub-folders will be "Cura" and it will contain the Cura settings.
You can use an app like 7-Zip to open any 3mf archive and view what it contains. If there is a Cura folder in it then it should open as a project. If there isn't, then it will open as the model only.
