Why does the Ultimaker Cura not give the option to load a Lultzbot printer machine when they offer so many other printers? That would be another work around?
I am not aware of any changes in info.plist files making ancient versions of Cura and Python work on modern Apple processors. I do know that all Windows and Mac OS versions of Cura come with their own "baked in" version of Python (2.7 for legacy Cura, 3.5-3-10 for newer Cura), so installing a version of Python on your system doesn't really change anything as far as Cura is concerned.
Ultimaker only creates and maintains profiles for Ultimaker printers. All other printer definitions and profiles are created by other manufacturers (like Lulzbot) or community members. An effort to get Lulzbot printers included in Ultimaker Cura is underway here:
https://github.com/Ultimaker/Cura/pull/10232
Edited by ahoeben-
1
ahoeben 1,800
You are going to have to ask Lulzbot, not Ultimaker. The 21.08 version is based on a version of Cura that Ultimaker stopped developing in 2016. Also Lulzbot have been making fairly major changes to the original Cura code since 2015, so it is hardly recognizable anymore. Finally that version just depends on too many 3rd party components that are no longer working on a modern Apple computer, such as Python 2.7 (as you already found out).
If you want to keep using Lulzbot Cura 21.08, you are probably going to have to do so on an older computer.
LDG-CO 0
I did ask the Lulzbot support team since I'm certain that I'm not the only one that would still like to use 21.08. Unfortunately they were not helpful. (See attached) Ever since the Lultzbot company was sold they do not seem to care about their earlier models or their very long time supporters. They also do not seem as helpful as the when the company was in Colorado pre-sale. I got a too bad response without any direction as how to solve the issue. So trying to get any kind of solution I ask if I could load the printer as a TAZ 5 and tweek it but got no real help there either. I have since also put this issue on the Lultzbot Community board and have yet to get any insight as to how to fix this.
As an FYI - to correct your statement above, actually Cura 21.08 works fine on Python 2.7 which comes preinstalled on the older macs.. Cura 21.08 works just fine on a mac using the OS High Sierra 10.13.6. Apparently the new M2 does not come with python installed so I had to download the new Python which I did. I now need some direction as to how to "edit' the "Info.plist" to tell Cura how to use it. This requires someone with the right knowledge which I've yet to find. I am not familiar with the inner workings or how to edit the file. Certain someone out there has the right knowledge to get the answer for many out there.
-Or - Alternatively --- Is there a newer version that 21.08 Lultzbot Cura that lets you set up a printer selecting a Buddaschnozzle as the extruder on a Taz 3 or 4. These settings will also be for the z rods before the upgrade on Taz 5. Thanks
