Support transition issue
Posted · Support transition issue
I've noticed now that for some reason, when it transitions from support to the actual object it will print, it will create this stringing effect but it's much more solid and I can't find any way to fix it. I tried toggling some settings in the slicer but nothing seems to work. Any ideas?
image.thumb.png.143fe260508f007387e583e447a6207b.pngimage.png.4ef8750a835fc7c4ce142e61a7344010.png
        • 26 replies
