Heated Chamber Plan for Ultimaker Original
Posted · Heated Chamber Plan for Ultimaker Original
Hello, I've finally published heated chamber design here. When I needed to print with ABS I just covered the whole printer with bubble wraps, but finally had some spare time and put things together to share.
Hope you enjoy.
