Generic HIPS?
Go to solution Solved by JTMD,
Posted · Generic HIPS?
The 'Generic' materials are bundled with Cura, so you wouldn't see those in Marketplace. Well, more than just bundled, because so are the UM materials, and you can see those just fine in that spot, but the 'generic' ones are the bedrock everything else is based off of, and so are treated in special ways.
(And for the other way around, when you don't see any materials in the dropdown that you installed, that might be because some materials are 1.75mm or 2.85mm only.)
    • Solution
    Nope..  turns out the software specifically excludes generic hips.. don't know why, it's the only material listed in the exclusion list.  It's possible to change it but the next Cura update with put it back..
    No biggie,  I just use a manufacturer's HIPS instead.
