Do you need dual extruder printer ? If so, well, there is not much available at "ok-price" as a desk printer. I have a UMS5 that I can hardly recommend, but I admit that I don't know much about other dual extruder desk printer.
If you don't, then go check some Youtube video about recent printers, there is a bunch really really cool, and you'll probably end up with a BambuLab machine. Don't by a Ultimaker printer if you're not extensively using dual extruder.
Precision won't really exceed 0.05mm and is not worth it either. 0.06-0.1mm is enough for me for most application, even when I need some visual. But it's not Resin-tier precision.
Dustin 53
Well you asked this question on a UltiMaker Community.. I would look into the UltiMaker S3 or S7.
If this out of your budget, you should probably ask somewhere else.
