Cura 5.3 questions
kgu
Go to solution Solved by ahoeben,
Posted · Cura 5.3 questions
Hello,
I am testing out the Cura software to see if I can edit my 3d objects before I print using my non-Cura 3D printers. The current 3D printers I work with are the Stratsys Objet 30 and using Formlabs 2/3 printer.
1)How can I put a name label on the 3D object itself? I would like the name engraved inside the 3D object for identification purposes.
2)Is there a function in Cura where I can automatically repair the 3D object before sending it to print?
3)Because my printers are not from Cura, is there a way I can save my 3D object as an STL file after I'm done making edits to it?
Thanks
    • Solution
    Cura is not a 3d modeler, but a slicer for FDM printers. In other words: Cura is not meant to make edits to STL files.
        • 56 replies
        • 34 replies
