GregValiant 1,492
It's hard to tell from far away but that looks very over-extruded. Have you calibrated the E-steps on the printer?
Make sure that the filament size is correct in Cura.
In the Machine Settings dialog make sure you have the Gcode Flavor set to Marlin (and not Marlin Volumetric).
On the printer control panel go to the Control / Filament menu and make sure "E in mm3" is turned off.
Also check (just to make sure) that "Remove All Holes" is turned off in Cura.
lalosion 0
Using a Ender 3
