Understand retraction settings (calibration plugin)
PsySc0rpi0n
Posted (edited) · Understand retraction settings (calibration plugin)
Hello.
I need some clarification on how I am editing a post-processing script to make sure I'm understanding the values and how to change them correctly.
I'm using Ultimaker Cura 5.3.0 and I downloaded the Calibration Shapes plugin v2.2.2 from Market place.
Then, I'm using the Retraction Tower with some basic settings like:
Temp: 210ºC
Bed temp: 50ºC
Layer Height: 0.2mm
Infill: 15%, Gyroid
Print Speed: 50mm/s
Retraction: Enabled
Retraction Distance: 1mm
Retraction Speed: 25mm/s
Retraction Layer Change: Enabled
Then, in the post-processing script named "Retract Tower" I have it like this:
However, I'm not sure the Change Layer Offset and the Change Layer settings are correct, because for instance, the number of layers of the base, seems to be to be 3. Please confirm if I'm wrong:
layers-base.thumb.jpg.069445723b78e65347096d1554c5a886.jpglayers-base-1.thumb.jpg.23e25a27bce3d815b1f0274665c6b526.jpg
And then, the amount of layers of each section, seems to me to be 39 and not 38 as the default values suggest, despite the fact I've seems some videos of people using 4 and 38 respectively.
From the image above of layer 4, which seems to me to belong already to the first section of the retraction tower, and then moving up the slider until the last layer of this same section:
section-1-last.thumb.jpg.16e8e81334fc178936208e977867c65a.jpgsection-2-first.thumb.jpg.252d2367899f7b15107b2acc97184fa1.jpg
So, shouldn't my values be as I posted at the beginning of the thread?
Edited by PsySc0rpi0n
        • 27 replies
