Posted · How do I add support inside my 3D Model to remove it later ?
I have a model that I vertically split in 2 parts,
I remove the bottom layer (where is the cut of the half part)
I wondering how to put some support INSIDE the 3D Model (not only outside) ?
I uderstand I can only put Infile ? so I put a thin bottom + 5% infill line to add some support but may be I'm doint it wrong ? My goal is to be able to remove the inside at the end and stick the both part together keeping a hole from bottom
    if this is a hollow model you could try with support blockers..
    But if this is just a model you are trying to print with zero infill.. you will need to adjust the model with 3rd party software (meshmixer or something) and make it "shell" with thickness to it for UltiMaker Cura to generate support.
