Posted · Ender 3 S1 color change.
Having problems with color change mid print , on my ender 3 S1 using Cura 5.3...  it stops , beeps like i told the gcode to do... but wont resume   just sits thee goes cold ...  im missing a step... i go into filemnt change .. type m300 before gcode , did my layer height stop. But getting mixed info on after gcode in that menu..
  Am i in tje wrong menu .???
    What post processor are you using?
    "Filament Change" uses M600 and puts everything on the printer firmware.  If the printer doesn't support M600 it doesn't work.  M600 supports several parameters and maybe you aren't getting them all in there correctly(?).
    "PauseAtHeight" puts everything into the gcode so it isn't dependent on the firmware BUT your firmware needs to support M0 or M25 in order to pause.
