Bug? Prusa Mk3s+, 0.6 Nozzle, wall thickness automatically 0.8? (Cura 5.1.1)
Posted (edited) · Bug? Prusa Mk3s+, 0.6 Nozzle, wall thickness automatically 0.8? (Cura 5.1.1)
I've recently bought the E3D Revo, so I'm switching nozzles a lot - and having troubles.
I noticed that even when I tell Cura that I have a 0.6 nozzle, the wall thickness is 0.8 . Line width changes correctly, I've checked. The wall thickness value is not entered manually, and line count is 1.
Shouldn't the wall thickness be 0.6?
[edit] Just checked with a default profile and Cura 5.3.1 - still 0.8 . Either I'm misunderstanding something or my settings are completely borked.
Edited by Rejutka
    Posted · Bug? Prusa Mk3s+, 0.6 Nozzle, wall thickness automatically 0.8? (Cura 5.1.1)
    Wall thickness isn't the nozzle size.
    Wall thickness is something specific to Cura - you can says how thick you want the wall vs how many walls you want (it supports either option)
    So 2 walls or 0.8 = same thing.
    Changing the nozzle size won't auto recalculate that, you will need to change it on your own.
    The slicing engine will still try to complete 0.8 wall thickness with your nozzle however.
        • 56 replies
        • 34 replies
