I had a similar issue and found "Make Overhangs Printable" was ticked in the experimental section in Cura. If it's ticked, untick it, and hopefully that will fix your issue.
I just found the problem.
I had missing faces betweend the 2 bottom layers, so the walls were open.
I selected on the edges of the two layers and clicked on "Bridge Edge Loops".
gleff 1
crrizzman 0
Now it works as expected in cura.
