there was a script you could run your gcode thru that would vary temperature every layer depending on your settings. it was good for making wood filament look more "real" because the darkness of the filament changes alot with temp. are you thinking of something like that but perhaps with layer height? oh line width.. i dont think thats a feature ive never hard of it idk. have you seen "fuzzy skin"? maybe not the effect your looking for...
GregValiant 1,044
I don't understand.
Is that a section through the model and planar-parallel to the build surface?
Is that a single toolpath (one layer in spiralize) with those wide spots being over-extruded and then the narrow spots being under-extruded?
