Cura AppData>Roaming>cura
Posted · Cura AppData>Roaming>cura
When I install Cura I open it up setup (Ender 3 2v Neo) my printer. It seems OK, When I restarted again it freezes right after the loading screen. If I delete profile, AppData>Roaming>cura then I can start the process again... But it's going in the loop...
  • I disable my Norton.
  • I even make a new account in windows.
  • I have tried uninstalling.
Event viewer:
Faulting application name: CuraEngine.exe, version: 1.0.0.0, time stamp: 0x643fb550
Faulting module name: ucrtbase.dll, version: 10.0.22621.608, time stamp: 0xf5fc15a3
Exception code: 0xc0000409
Fault offset: 0x000000000007f61e
Faulting process id: 0x0x1840
Faulting application start time: 0x0x1D988D152ED9F1B
Faulting application path: C:\Program Files\UltiMaker Cura 5.3.1\CuraEngine.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 6312d524-0831-4562-9f6f-504051d87c25
Faulting package full name:
Faulting package-relative application ID:
        • 56 replies
        • 34 replies
