1 hour ago, Dustin said:However, it sounds more like your front fan isnt working properly?
Make sure your front fan is clean and spinning properly when your print cores are heated.
Thank you Dustin. How do I cause the fan to switch on? I have tried raising the temperature of one of the print cores but the fan does not switch on - which I expected it to. Am I right in thinking that once the print core(s) are above a certain temperature, the fan should come on automatically as the fan on my machine does not move at all.
1
Dustin 160
The following is a guide for loading materials on your UltiMaker S5
https://support.makerbot.com/s/article/1667417952533
