I want to try this as a way of eliminating touble I am getting with the walls on small (2mm to 4mm) internal circular holes not properly adhering to the main infill. NOTHING I've tried from commonly recommended settings changes has worked thus far, and a single alternating wall isn't enough to properly overlap the infill with the inner walls and anchor them together. And that is even with having massively increased the overlap percentage settings.
I do tend to use fairly high density infill, so 5 extra perimeters every 10th layer would work fine for me, though what I'd initially want to try is 3 extra perimeter walls (for inner walls only) every second layer.
Having multiple perimeter walls alternating should give a much better trapping of infill (especially high density infill) than a single alternating wall can, and should help combat any shrinking of the hole walls which might be the reason they pull away from the main infill, see this:
https://www.eevblog.com/forum/3d-printing/under-extrusion-around-the-edges-of-circular-holes/
Thank you
Edited by r111122223333
GregValiant 1,320
"I want to add say 2, or 3 or even 5 extra walls (perimeter) lines on every alternate layer, ..... on every Nth layer...?"
There are no settings to do something like that.
You can alternate a single extra wall I think that thought behind that is to trap the infill at the walls.
"...apply only to inner walls, while just leaving a fixed wall count on outer perimeter walls."
I'm not sure I understand that one. I'd say that because the answer to the first question is no, that this one doesn't come into play.
Wouldn't 5 extra walls every 10th layer result in those extra wall extrusions being printed over air? You would need pretty high infill density to hold them up.
