Try pressing the little "Fx" symbol next to the Wall line count. You should then be able to change the Wall thickness. I think that if you type a numeric value into the Wall line count setting it will override the Wall thickness. As far as I know the Wall line count is a calculation of the Wall thickness and it changes automatically when you change the Wall thickness.
Yep thanks for that. I have used this so many times and never had an issue. In fact you have to click the fx symbol on the Wall Thickness + Wall line count before it allows you to input. Then as you say when you change the wall thickness it automatically adjusts the wall line count. Weird how I never experienced this before. They need to fix this as it is not logical...
Badgersurfer 2
