I use Fusion360 and export the models as STL.
Is there a better file format to use? Or are there export setting I need to use or check for?
That's what I use but from Inventor. Models from Fusion are usually fine.
The Fusion STL exporter may have user settings. You would need to search for them.
If you can share the model then load it into Cura and use the "File | Save Project" command. Post the 3mf project file here.
Edited by GregValiant
GregValiant 1,112
I would guess something in the CAD model or more likely, the exported file. The "wants to fill with infill" is a clue that the model that showed up in Cura is not shelled properly.
