50 minutes ago, GregValiant said:Hi @Garythebloke.
The Post Processing alters the gcode that is written to the file. The method it gets to the printer (SD, USB, Octoprint) doesn't matter.
From the top:
Go to "Extensions/Post Processing/Modify Gcode" and then "Add Script".
Select either Filament Change or Pause at Height. Either will work.
Choose your settings.
Slice and save the gcode.
Open the Gcode file in a text editor.
Do a search for the command used for your color change. Filament Change uses M600 and Pause at Height is adjustable so you would need to remember the command you used in the Pause settings (often M0) .
GregValiant 1,112
Hi @Garythebloke.
From the top:
