- Solution
I figured it out. I use IdeaMaker for import as it has detailed reporting and error correction. Then I export from IM and import into UM Cura. I don't really care about the errors--just how to fix them. Frankly, when I build something in Blender or anywhere else, the errors shouldn't exist at all and reflect non-standardized, fragmented, poorly developed build systems. That IM can fix it (slowly) is awesome. That UM Cura is easy on the eyes and has a variety of pre-made printer templates, also awesome. So--although this is sort of a dumb problem that shouldn't exist but does and isn't really fixed, the dual-system workaround works. If Idea Maker's UI looked a little better, there wouldn't even be a need for a dual system.
Dustin 145
Recommend sharing a Project file with one of these models for better help.
