Thank you for such a quick answer !
I am afraid that the problem may have to do with some configuration on my side... there is extrusion but it does not begin where it is suposed to begin. It should start from a supported position and then, "build" the bridge. But it does not. The nozzle gets into the bridge area (on air) and then begins to extrude when there is no support position and I have no idea about how to correct this.
GregValiant 1,320
I don't get that at all in the gcode. Every line in the bridge shows as an extrusion.
This is the first layer of a bridge
;TYPE:SKIN
;BRIDGE
G1 F2250 X163.459 Y110 E2760.05975
G0 F9000 X163.459 Y110.4
G1 F2250 X130.806 Y110.4 E2760.71138
G0 F9000 X130.806 Y110.8
G1 F2250 X163.459 Y110.8 E2761.363
G0 F9000 X163.459 Y111.2
G1 F2250 X130.806 Y111.2 E2762.01463
etc, etc,
;TYPE:WALL-OUTER
;BRIDGE
G1 F1500 X164.8 Y133.07 E2730.17987
G1 X164.8 Y108.47 E2730.58897
G1 X131.467 Y108.47 E2731.1433
You can check your gcode or load the model and set Cura up then use the "File | Save Project" command and post the 3mf file here.
