I get what your saying but why did Cura add that bottom layer of text? According to Tinkercad there is no layer of text on the bottom. In fact the text should not even start until 1mm in height. I have also used the same template to create approximately 25 tags with different names and never run into this problem.
GregValiant 1,112
Honest Ghostguy6, Cura has absolutely no capability to do something like that. It's a slicer not a CAD program.
Something went wonky, but it couldn't have been Cura.
GregValiant 1,112
The letters on the build plate side are raised and so they are the only thing touching the build plate. The skirt is going around the letters.
This is looking up through the bottom of the build plate. The cyan of the letters indicates that those areas are in contact with the build plate. The red surfaces are indicating that they need support which means they are not on the build plate.
Here you can see the skirt is respecting that part of the print that is in contact with the build plate.
