Ultimaker Cura 5.4.0 stuck at "Loading preferences..."
Posted
(edited)
· Ultimaker Cura 5.4.0 stuck at "Loading preferences..."
On 7/20/2023 at 10:38 AM, ahoeben said:
Try renaming cura.cfg in C:\Users\user\AppData\Roaming\cura\5.4\ to cura.cfg.bak.
This helped initially, however Cura started the setting up process every time after booting.
I deinstalled Cura 5.4, deleted all data in AppData\Roaming\cura\, including data from old Cura versions. Afterwards I reinstalled Cura and restored an old profile. This fixed it!
Posted
It looks like somehow Cura was not allowed access to write to its configuration folder. This could be a result of launching Cura "as administrator" in the past. Best not to do that.
ahoeben 1,850
Try renaming cura.cfg in C:\Users\Niki2\AppData\Roaming\cura\5.4\ to cura.cfg.bak.
Smashbroser 0
Edited by SmashbroserClarification
