Failed slicing if part of object is below build plate
Posted
(edited)
· Failed slicing if part of object is below build plate
That hasn't changed and I just did a print that way this afternoon. There are slicing problems with 5.4 but I haven't seen anything indicating that it is related to the Z location of the model.
There are three workarounds that either separately or in combination may fool the bug.
Move the model to different locations on the build plate.
Rotate the model.
Change the Initial Layer Height by just a little (Ex: from 0.20 to 0.23).
But there are definitely error-free models that 5.4.0 simply refuses to slice.
EDIT: If a model extends past the build plate in the XY it won't slice. That is true even if the part that sticks out is below the build plate. That has not changed.
Posted
Thank you for the response. I think you are correct and 5.4.0 was just refusing to slice that model at all. Same with 5.3.1. It was still slicing fine on 5.2 versions.
Hopefully they figure out the slicing issues with 5.4 soon enough.
GregValiant 1,318
