Hi, Thanks for the response. I've been doing that but it kinda stopped worked. Maybe my profile settings are set up incorrectly? I can see it's selected but when see the outcome after I slice using the slider on the right, it doesn't show that it is the second filament.
Bizarre.
alfonsvh 12
First make sure that your extruder materials are correctly set on the top of the screen:
Next, right-click each object and select the extruder you want to use for each of them.
