Ultimaker S5 Air Manager - does it help reduce noise?
Larpushka
Posted (edited) · Ultimaker S5 Air Manager - does it help reduce noise?
We've had our air manager for quite some time already, but I do remember that it did reduce the sound noise significantly when we added it.
Yes, it does come with the continuous passive noise from the fan, but it reduced the peak noises from the travelling of the print head. So the sounds that are actually annoying are reduced significantly.
Edited by DDoove
    • 9 months later...
