Is there a setting I have triggered to make the top tool bar become lower? Currently I'm using Cura 5.4. I have had this issue of it covering up my x axis movement measurements.
Go to solution Solved by ahoeben,
Posted · Is there a setting I have triggered to make the top tool bar become lower? Currently I'm using Cura 5.4. I have had this issue of it covering up my x axis movement measurements.
    • Solution
    I think this is an oversight, resulting from using a low resolution display and possibly having a couple of plugins installed that add icons to the toolbar.
    One workaround would be to install the Sidebar GUI plugin from the Marketplace. It rearranges some UI elements, and as a side-effect it mitigates this particular problem.
    • 2 weeks later...
    Thank you for taking the time to respond. It worked amazingly and soooo simple. thanks again. 🙂
    6 hours ago, ultimogiro said:
    Thank you
    You are welcome!
    Note that the Sidebar GUI seems to be "addictive"; once you get used to it, Cura without the plugin is just a bit less nice to work with. The plugin always needs to be updated for new versions of Cura. I try to publish such updates in a timely fashion (normally during the beta period of a new Cura version), but sometimes you have to wait for a couple of days.
